Can someone help me figure this out? I recently installed a new version of Ableton and when I try to rewire with VDJ it says it does not recognize my new Rewire engine.
So, the message reads, to turn each program off individually turn Ableton back on so it can install it's new Rewire engine.
After I do this it just repeats the same thing, it never installs anything does anyone have a clue on how to reset this etc ?
Posted Thu 03 May 12 @ 12:59 pm
I too have a Rewire not being recognized issue....
I have a fresh copy of VDJ 7.05 (loaded first), followed by Ableton APC40 v 8.3 (loaded second).
I should be able to go right into Advanced Audio Config (in VDJ) and choose Ableton via Rewire, but no option appears???
Best, JF
Best, JF
Posted Sun 21 Oct 12 @ 11:29 pm
Are either of you running 64 bit computers?
ReWire needs both applications to be in the same "bit mode", so if you're running VDJ (only 32 bit AFAIK) and the 64 bit version of Live then ReWire won't work.
Posted Mon 22 Oct 12 @ 5:14 am
Useful to know... I think maybe that's why it's never worked for me. Thanks.
Posted Mon 22 Oct 12 @ 4:10 pm
note: was talking to the ableton support there was a issue in one of the ableton downloads. I had to update it as the rewire was screwed.. the company sent me a link to the issue and support.. the issue was in 8.2 now the version is 8.3.4.5
http://www.ableton.com/support/contact
Posted Mon 22 Oct 12 @ 6:28 pm
