Hercules 4-Mx mic input and button works when VDJ is not running. When I start VDJ the button that turns on the mic stops working. I also have a RMX and the mic button works as it should when VDJ is running. This behavior happens on both my gigging laptop and my desktop.
Everything else works fine on the 4-Mx. This is not much of a problem for me since i have a mic mixer in my rack but i want it to work when I gig at a place i do not bring my rack along and there is no mixer around.
Setup
Laptop
Core 2 duo
4gb ram
win 7 64 bit
Desktop
Core 2 Quad
8gb ram
Win 8 preview (yes it runs VDJ well)
Thanks for your help.
Setup
Laptop
Core 2 duo
4gb ram
win 7 64 bit
Desktop
Core 2 Quad
8gb ram
Posted Tue 24 Apr 12 @ 9:39 am
hey DAZ , nice avatar , looks like an XARA
if i had the 4mx i'd give it a spin and get back to you.....
have you tried searching at the Hercules forum ? give that a shot ...
Posted Tue 24 Apr 12 @ 8:17 pm
VDJ disables the Talk Over function of the 4-Mx in order to use the microphone as an external source and recording.
In order to use the mic, be sure to set the audio configuration as follows:
- Input : Microphone
- Output(s): Headphone
-Soundcard: DJ Console 4-Mx
Doing so, when pressing the Mic On/Off button, Deck A will switch to external source and the microphone will come thru.
Posted Wed 25 Apr 12 @ 6:18 am
speaking of the Hercules forum .......
Posted Wed 25 Apr 12 @ 7:50 am
Posted Wed 25 Apr 12 @ 8:54 am
Thanks to the VDJ community for your help. The suggestion worked.
Posted Wed 25 Apr 12 @ 11:46 am
Thank you DJ Phatso. Your solution helped me as well!! =D
Posted Tue 22 May 12 @ 8:14 pm
I was experiencing the same issue with the mic. now it works but what causes the setting to change?
Posted Fri 20 Jun 14 @ 12:24 am
