Wondering if I can use the MC6000 and iRemote to control VDJ at the same time without having to make any changes. For example, if I'm behind the mixer I'm controlling it that way, but if I need to step out to lead a dance or interact with the crowd I can still control via the iRemote. Is this possible?
Posted Mon 23 Apr 12 @ 3:46 pm
Yes. It will work just fine.
Keith
Keith
Posted Mon 23 Apr 12 @ 4:15 pm
Is there any buttons I would have to enter to make the switch over?
Posted Mon 23 Apr 12 @ 5:35 pm
Are you asking if Iremote will look like the 6000? No (unless they made a skin for it) I use it occasionally and it works fine. No changes whatsoever
Posted Mon 23 Apr 12 @ 10:11 pm
In principle it would be just like using two "normal" controllers at the same time.
This is normally done for extra functionallity like supporting 4 decks or having additional controls for effects. That's fully supported and doesn't require any switch-over
/HS
/HS
Posted Mon 23 Apr 12 @ 11:45 pm
