I have an acer laptop. I am trying to monitor with headphones but i can't. I have tried serato djintro and it works with that. I have tried all the settings VDJ have advised and even had remote assistance. Even he couldn t find out why this was happening?! anyone help?
Posted Sat 21 Apr 12 @ 7:15 am
Hi
You need to provide a few more specifics.
What OS do you have on the laptop?
Where are plugging the headphones in? (it should be the N4, not the laptop).
You say that with DJ Intro "it works" - what works?
If you're using the VDJ LE version that came with the N4, there is no setup or configuration. The whole thing should be plug & play.
Posted Sat 21 Apr 12 @ 10:57 am
Double post, please remove.
This is the reply I received
Hi. The N4 setup is little tricky because Numark did not wrote a dedicated driver for it but instead they use the generic Asio4All, which is actually a wrapper -> you have to tell this driver which of your soundcards to use, and to do that you need to make sure no application in the computer that can access audio is open or running in the background. Detailed Instructions :
As Numark recommend you have to install the Asio4all driver (www.asio4all.com). IMPORTANT : Select the option to include "offline settings" during installation. (reinstal if needed) Run the offline driver utility (from Windows start menu) without any other software running (even the internet browser) Then configure the driver to use the Numark soundcard NOT the onboard soundcard. Close the driver control panel.
The correct virtualdj settings will be : Inputs : None Outputs : Headphones Soundcard : Asio > Asio4All
Posted Tue 10 Jul 12 @ 12:23 am
Install ASIO4all download from numark website under controllers N4 tab
click little box offline settings
install virtual dj le (also download from numark website)
****** CONNECT N4 CONTROLLER ****** to computer's usb and TURN ON (soundcard is inside controller)
open ASIO4all program from star menu
you will see your computer's soundcard and N4 souncard
grey out your soundcard and keep N4 lit up exit out of ASIO4all program
now open virtual dj
Virtual dj will recognize ASIO4all sound driver
settings
input none
headphones
ASIO > ASIO4ALL
It should work now
now open virtual dj
settings
input none
headphones
ASIO > ASIO4ALL
It should work now
Posted Sat 14 Jul 12 @ 8:58 pm
