Hi, when i put on a large mix (like a hour and a half) i can't seem to use the backspin or brake or any effect?
(VirtualDj Pro 7.0.5b, PC, Hercules Dj4set)
Whats with that ?
Greetz. Djef
Whats with that ?
Greetz. Djef
Posted Mon 16 Apr 12 @ 11:16 am
Could it be that you´ve set max load to ex 15 min ? Check the settings under options,there you´ve got a option called max load(I think it´s called that) Try increasing it and see if it solves your problem.
Br
/Aron
Br
/Aron
Posted Tue 17 Apr 12 @ 6:25 am
Yes, you need to have loaded the entire track to RAM. If it's not preloaded then FX will not work.
Keith
Keith
Posted Tue 17 Apr 12 @ 7:01 am
I use my external 2.0 TB Elements HD. It has a 2.0 USB connection.
That can't be a problem right?
greetz Djef.
greetz Djef.
Posted Tue 17 Apr 12 @ 8:05 am
