Is there a way to run virtual Dj and fl studio ( fruity loops) in the same way that you can use Ableton as a rewire add on?
Posted Wed 11 Apr 12 @ 6:57 pm
The cheapest FL Studio doesn't have ReWire, so it depends which version you're using.
Posted Thu 12 Apr 12 @ 7:09 am
Yes. I do it all the time.
Posted Thu 12 Apr 12 @ 8:19 am
Thank you. I have producer edition. I am only new to fl studio can u direct me to a link where it tells me how to do the rewire? My vdj is 7.05 if that helps.
Cheers
Cheers
Posted Thu 12 Apr 12 @ 2:32 pm
rewire instructions are in the vdj user manual... cant remember which page, Dj Cyder pointed me to it recently..
Posted Thu 12 Apr 12 @ 3:13 pm
Audio setup guide actually. And it can be found here >> https://virtualdj.com/images/pdf/VirtualDJ%207%20-%20Audio%20Setup%20Guide.pdf
Posted Thu 12 Apr 12 @ 6:21 pm
Thanks I will give it a go. Thankyou for your help
Posted Fri 13 Apr 12 @ 8:32 pm
yeah that one.... page 18 :)
Posted Sat 14 Apr 12 @ 1:36 am
Thanks. It's all up and running thankyou for your help.
Posted Tue 17 Apr 12 @ 3:22 pm
