Topic: MIXER NOT WORKING BUT SPEAKERS ARE HELP!
I just bought my first audioline Dj set http://www.audiolinepro.com/Prodjpack.html and I can't get the mixer connected I don't know If I have to but other connection I try to change Setting in the config but it doesn't came with external mixer option I have virtual djle please help! Thank you I'm using windows a toshiba laptop I am new to this
Posted Tue 10 Apr 12 @ 2:23 am
Which mapper would be the best for the above controller
Thanks heaps
i just seen that ther isnt a mapper for your controller... maybe use ASIO i reckon and fiddle around with it
check the CD that came with it, that might have some info on mappin
•Hardware Key remapping via included software
The only option is audio 8 DJ I click apply and it cames up error in the asio sound drive. Your soundcard is probably not connected or the settings are incorrect...
I've never heard of that controller .... but given it comes with virtual DJ LE you should just plug it in to USB, start the software and off you go, no configuration required.
Was there a quick setup guide with the kit?
Keith
That's the problem it doesnt give me the option of USB, it only cames up at option primary sound drive, speaker (3-control main), speaker(3-control headphone), speakers(conexant cx20671 smartaudio HD). Sounds comes out of speakers or headphones which are connect to the controller or sounds come out of the laptop but can't use anything on the controller besides the master volume
That's as simple as it told me to do in the manual just can't get the USB selection
The master sound comes out of master outputs on the back (3-control main) and headphone pre-listening is via the headphone socket on the front (3-control headphone)
Your sound settings should be as follows:
Inputs: None
Outputs: Headphones
Sound card: 2 cards -> Pick 3-control main in 1st box, 3-control headphone in 2nd box.
Click APPLY.
If the sound is working OK but the controller doesn't control VirtualDJ (E.g: Turning the jogwheel, pressing PLAY, etc. has no effect), then it means that the MIDI/HID part of the controller is not working.
First, make sure that you have the most recent version of VirtualDJ LE installed. You can download it from the Download Center: https://virtualdj.com/download/updates.html
Please also see the following page: https://virtualdj.com/wiki/MIDI%20Controller%20Not%20Working.html
