Okay, so I just purchased two Gemini CDJ700 and the Behringer DJX900, and I'm not able to get the audio from channel two on my headphones, everything else seems to work just fine with that minor exception. Any ideas on how to solve this small problem?
Posted Fri 30 Mar 12 @ 11:08 pm
Is the unit near any vegetables or water? What is your output?
Posted Fri 30 Mar 12 @ 11:25 pm
The only vegetable is me, and I think I just water myself.....
when I go into the Sound set up, it only give me the two usual choices that VD gives you, and I tried both but still I can't get the sound from channel two on my headphones, and then I went into Asio settings to see if I was able to configure it, and somehow I made a bigger mess.
Posted Sat 31 Mar 12 @ 2:00 am
Are you sure you dont have the level and mix knob turned opposite?
Posted Sat 31 Mar 12 @ 2:08 am
Tried every single thing you can possibly imagine, including the knobs...heheh, and nothing. Here's the kicker, I was using my Radius 3000 with my other laptop, and never had a problem with the USB connections. I decided to check out the gemini's with this laptop (Toshiba) and for some reason it would not read one channel, but on the newer (Dell) lap top it does pick up both CDj's.
Posted Sat 31 Mar 12 @ 2:45 am
Problem solved, it all had to do with the configuration of the Gemini sound card settings, and how I was connecting to the mixer.
Posted Sun 01 Apr 12 @ 1:51 pm
Seems like I saved the day :D
Posted Mon 02 Apr 12 @ 2:46 am
"Are you sure you dont have the level and mix knob turned opposite?" SHHHHHHHHHHHHHHHHHHHHHHHHHH don't tell anybody, but you were right....ahahahahahahahah
Posted Tue 03 Apr 12 @ 10:02 am
what are the effects defaults on this shit ?? i started messin with it now i cant get it back to how it sounded
Posted Thu 05 Apr 12 @ 1:30 pm
Please start your own thread and be more detailed about your issue. Hi-Jacking someone else's thread is frowned upon here.
Since DJ Ho has solved his issue, it is safe to say that this case is resolved and we can lock this thread now.
Posted Thu 05 Apr 12 @ 4:31 pm
