Topic: Mapping question on mixtrack pro!!
I am trying to map my mixtrack pro to 3 deck use so i am facing these problems but i will also tell you how i mapped.
Master volume mapped as deck 3 volume slider
back button as deck 3 load
stutter as deck 3 play pause
keylock as deck 3 select
so i want to map either one of the effect control knob into jogwheel touch so that i am able to make a "jogwheel" for deck 3 so how am i able to do it? I tried using the jogwheel/touchwheel +1.0 and it doesn't act like the jogwheel as it can only forward the song when i turn the knob in back and front. (hope you understand me at this point)
or is it possible for me to map the pitch bend button as deck 3 and 4 select so that the whole mixtrack pro will be divided as deck 3 and 4, also 1 and 2 .
Posted Mon 26 Mar 12 @ 1:48 am
Hey guys Im having a problem mapping new effects to my mixtrack pro II does anyone know how to do that. I'm using virtual Dj, but mapping the actual effect it's self is whats proving to be the problem.
Click on the first link Synth posted..........
