http://www.youtube.com/watch?v=BO_An_MiFc8&context=C40e77a4ADvjVQa1PpcFNVpTrEecDhFxMUcaWTmtiAA__uPiqNoc4=
I can use all the (constructive) criticism I can get!
Posted Tue 20 Mar 12 @ 1:17 pm
Your mix would have been better suited in one of the music forums, it will get a better response down there. Ask a moderator to move this post for you.
Posted Tue 20 Mar 12 @ 3:39 pm
Ok.. let me be the asshole to give it :P Its not a mash its a mess .. that was the critical bit now for the constructive bit...
- Read the great mix lessons on https://virtualdj.com/forums/6288/Mix_lessons/DJ_MIXING___basic_-_advanced_-_pro.html
- Especially focus on the parts dealing with the structure of music; don't just be in sync with the beat, be in sync with the patterns
- Than start thinking of harmonics:
--> Never mash up tracks that aren't in harmony unless one contains mainly drums, percussion or effects
--> Be very careful of mixing vocals with vocals or instrumental solo's with instrumental solo's
And your best tip.. goto www.mixcloud.com or www.soundcloud.com and start listening well to what other people do. Get the songs and try it yourself.
Posted Tue 20 Mar 12 @ 3:48 pm
It does get better to the second half and I get the idea.. its just .. rough ..
Posted Tue 20 Mar 12 @ 4:00 pm
