Can someone please help me? When I plug in my ipod to my hercules rmx and hit input nothing comes thru virtual dj? Just says time code??
Posted Mon 19 Mar 12 @ 4:26 pm
Make sure before opening VDJ you check the settings on Hercules control panel. Make sure if you are going to be using both inputs select line in on channels 1 & 2. if not just leave it as is with mic on channels 1 & 2 and line in channels 3 & 4. Then open VDJ and change the settings on Sound Set Up. In inputs select "Line-Ins", which will allow you to use your ipod or any other inputs with your RMX when pressing Source button.
Posted Mon 19 Mar 12 @ 9:25 pm
Thanks a bunch man i got it to work finally!!
Posted Thu 22 Mar 12 @ 12:41 pm
