hi there guys, wonder if you can help
I have just purchased the maya44 USB to work with Virtual DJ Pro 7 and i have it all set up correctly (i think) the maya soundcard settings is s at 100% quality and 0.2 latency, so pretty good.
I just wanted to know how accurate the BPM indicators are with maya in VDJ as mine keep moving all over the place so its very hard to get the tunes to "lock in" and beat match. What i would like to know is, is this a normal occurrence using Maya44 or should they stay solid and not change BPM?
Also do you know if its possible to set a cue point from your cdj to match up with a cue point in VDJ? I cant seem to do this.
Here is my set up
1x Pioneer CDJ 800 mk1
1x Pioneer CDJ 800 mk2
Pioneer DJM mixer DJM-300 (old, but does the job :)
Maya44 USB
VDJ Pro 7 with VDJ Timecodes
Any feedback would be much appreciated!!
PEACE< DJ Benny J
Here is my set up
Maya44 USB
PEACE< DJ Benny J
Posted Thu 15 Mar 12 @ 7:13 am
Please register your Pro serial number on the page http://www.virtualdj.com/users/edit.html and then download the latest version from the Download Center: http://www.virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: http://www.virtualdj.com/buy/index.html
Once you have done this, please see the following page:
http://www.virtualdj.com/wiki/Timecode%20Vinyl%20Wow%20And%20Flutter.html
It's not possible set or use cue points in the software via timecode or control any other software function except for basic song playback. If you need to be able to use cue points in the software and other features, you will need to upgrade to newer MIDI capable CDJ's that can interface with and control the software directly without the need for timecode.
Posted Thu 15 Mar 12 @ 7:38 am
