hi there guys, wonder if you can help
I have just purchased the maya44 USB to work with Virtual DJ Pro 7 and i have it all set up correctly (i think) the maya soundcard settings is s at 100% quality and 0.2 latency, so pretty good.
I just wanted to know how accurate the BPM indicators are with maya in VDJ as mine keep moving all over the place so its very hard to get the tunes to "lock in" and beat match. What i would like to know is, is this a normal occurrence using Maya44 or should they stay solid and not change BPM?
Also do you know if its possible to set a cue point from your cdj to match up with a cue point in VDJ? I cant seem to do this.
Here is my set up
1x Pioneer CDJ 800 mk1
1x Pioneer CDJ 800 mk2
Pioneer DJM mixer DJM-300 (old, but does the job :)
Maya44 USB
VDJ Pro 7 with VDJ Timecode CD's
Any feedback would be much appreciated!!
PEACE< DJ Benny J
Here is my set up
Maya44 USB
PEACE< DJ Benny J
Posted Thu 15 Mar 12 @ 7:12 am
Please do not post the same message more than once.
You have already asked this same question in the hardware support forum:
https://virtualdj.com/forums/162127/x/
[Duplicate topic locked]
Posted Thu 15 Mar 12 @ 7:48 am
