Topic: Auto Deck switch at jog touching
Hi there, im looking for a way to disable auto deck switch whenever i touch a jog control in my MK4 console, is there any way?
Thanks
Posted Fri 09 Mar 12 @ 6:50 am
Sorry, in VirtualDJ LE, this is not possible because it is limited software and has no configuration options.
However, if you upgrade to the full Pro at a discount (Or use the 20 day Pro trial) then this is possible by disabling CONFIG -> Options -> Auto Headphones
To upgrade to the full VirtualDJ Pro, please go to: https://virtualdj.com/buy/
okay thanks for reply
