Hi,
I'm new to the midi controller game and I just wanted to know if you can trim manual loops like you can with Itch (see video):
http://www.youtube.com/watch?v=87bu8PE9CBU
I can't seem to get that to work, when I press the out button as instructed for itch, I lose the loop... any suggestions?
Posted Tue 06 Mar 12 @ 8:43 am
If you upgrade to pro you could map the 'out' button to
loop ? wheel_mode 'loop_out' ? wheel_mode 'jog' : wheel_mode 'loop_out' : loop_out
then the led to
wheel_mode 'loop_out' ? blink 400ms : loop ? on : off
then the led to
Posted Tue 06 Mar 12 @ 6:49 pm
Thanks for helping out! only problem: that all looked like Chinese to me... no idea how to map. I will upgrade though, I think it's time.
Is there a tutorial video on how get the mapping done? Like I said, I'm a newbie to all this! lol! thanks!
Posted Wed 07 Mar 12 @ 1:08 am
Posted Wed 07 Mar 12 @ 1:54 am
k, I'm going to upgrade when I get home from work today, but I'm hoping you can take me through the steps one by one... Because looking at it on my buddy's mapper (fully licensed)... seems to be quite a few "loops" and "led"s to choose from! lol!
Thanks for the help.
Posted Wed 07 Mar 12 @ 1:19 pm
do you have the ns6 or a different controller?
Posted Wed 07 Mar 12 @ 5:36 pm
I have the NS6. first midi controller. really never used software to dj before... lovin' the possibilities though! :)
Posted Wed 07 Mar 12 @ 5:40 pm
I went a little more. I wanted to be able to reposition the loop, and resize it with the wheel.
LOOP_IN holding 1500ms ? wheel_mode "loop_move" : var "shift_loop" ? loop_half : loop_in
LOOP_OUT holding 1500ms ? wheel_mode "loop_out" :var "shift_loop" ? loop : loop_out & wheel_mode "jog"
RELOOP holding 1500ms ? wheel_mode "jog" : var "shift_loop" ? loop_double : reloop_exit
LED_LOOP_IN var "shift_loop" ? on : wheel_mode "loop_move" ? blink 400ms : loop ? blink : loop_in
LED_LOOP_OUT var "shift_loop" ? on : wheel_mode 'loop_out' ? blink 400ms : loop ? blink : loop_out
This also let's me return to jog mode on the wheel. I have a MixTrack Pro, but it should work the same.
Posted Wed 07 Mar 12 @ 9:10 pm
