so i have my turntable connected and for some strange reason my BPM goes up and down in virtual dj, can anybody help me with that?
Thanx in advance
http://img141.imageshack.us/img141/5041/turntable.png <<< my scratch settings
Thanx in advance
Posted Fri 02 Mar 12 @ 12:37 am
in your timecode settings check disable clear sound,check apply noise lp filter,uncheck delayed and low your pitch sensibility at about 1.00% these are the settings that work for me...try them out..allthough you dont provide us many informations about your hardware setup
Posted Fri 02 Mar 12 @ 3:27 am
@fenderisc thanks for the help bro but it still off.
To be more specific, i only have one turntable (stanton t.55) connected to my hercules mk4. Deck 1 is my turntable and deck 2 is my left jogweel on my console but neway my turntables bpm dosnt stay at a constant speed is this normal or do i have to fix something in vdj? iIm new at at using turntables so sorry if it sounds like a dumb question(lol)
Posted Fri 02 Mar 12 @ 3:56 am
Any help from anyone?
Posted Fri 02 Mar 12 @ 10:17 pm
