Hey guys my name is Denis, I bought myself a numark mixtrack pro after reading around a bit on the site, btw its been really helpful,
Thanks to everyone who contributes to this site and to music in any way imaginable.
Enough social conventions now.
Before buying numark mixtrack pro and installing Virtual DJ LE that came with it, I downloaded Virtual DJ home edition, practiced with it and got used to it. I cant stand the LE version now, so... I was wondering if anyone knew if it was possible to make Mixtrack Pro use Virtual DJ Home as the default program, or maybe get a different skin for the LE version.
Posted Wed 29 Feb 12 @ 10:52 pm
Well glad you enjoy the site.....why don't you like the LE version???? but to answer your question, VDJ Home Edition can not use a controller...& with VDJ LE you can't change the skin....so you have 3 options..... 1. Don't use your mixtrack pro & stick with the home edition. 2. You can use your Mixtrack Pro & adjust to the LE skin or 3. You can upgrade to VDJ Pro for a great discounted rate & use your mixtrack pro & change the skin....
But if I remember correctly the VDJ LE skin & the VDJ pro one is exactly the same....
Posted Wed 29 Feb 12 @ 11:33 pm
alright thanks
Posted Sat 03 Mar 12 @ 12:37 am
