I have download the drive for the korg nano pad, but is not showing in virtual dj ,how to solve this issue? thank you
(sorry for my english,if there are mistakes)
Posted Mon 20 Feb 12 @ 10:46 am
Most likely you have downloaded an out-dated mapper from an unofficial and probably illegal source.
The Korg NanoPad is natively supported in the latest version. Please delete the mapper and then register your Pro serial number on the page https://virtualdj.com/users/edit.html and download the latest version from https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ, then please support the software and its future development by purchasing it: https://virtualdj.com/buy/
Posted Tue 21 Feb 12 @ 4:58 am
is the nano pad working with the LE virsion of VDJ?
Posted Tue 21 Feb 12 @ 7:18 am
No, LE only works with the controller it was included with, except during the 20 day trial of Pro.
NanoPad doesn't come with VirtualDJ LE included.
Only the full Pro supports using any native supported controller of your choice.
NOTE: If you use Pro trial in VirtualDJ LE, then depending on the age of the controller that it came with, it may not be the latest version and won't have support for newer controllers. You can check for a newer version of VirtualDJ LE by going to https://virtualdj.com/users/edit.html and registering its serial number to your profile. Then go to the Download Center: https://virtualdj.com/download/updates.html - In most cases, VirtualDJ LE will give you a discount off the cost of upgrading to the full Pro.
Posted Tue 21 Feb 12 @ 11:14 am
