Forum: Old versions
Topic: Virtual DJ Pro Basic with Numark N4
HI,
I bought the Numark N4 a while ago. The first program I used was Serato Intro, but then I understood that Virtual DJ was more technical advanced, eg. on Serato I don`t have Cue points or more looping options.. but on Virtual DJ they have.
Anyways,
I want to know what Virtual Dj version I should buy. I don`t want to pay too much so the cheapes and best solution in what I need.
Is the Virtual DJ Pro Basic a good alternative?
Thanks in advance!
Greetings, DJDani3L.
Posted Wed 08 Feb 12 @ 6:02 am
pro basic doesn't work with cotrollers just your keyboard... if you want to use the N4 you have to get the full Pro version, if you have the serial for the vdj le that came with the N4 you can enter it on the below page to see how much discount you will receive, it'll probably be between $100 - $150 from the $300 purchase price..
https://virtualdj.com/buy/
I see. Thanks synthet1c.
