Hello,
I am sorry to add a new topic when it has clearly been brought up before but I searched for about two hours and could not find a fix to my problem and became easily frustrated. I recently bought a Mixtrack Pro and everything works great except my headphones do not work with it.
My issue: I want to be able to plug my headphones into the Headphone jack and hear a cued song through them.
My sound setup:
Input: None
Output: Headphones - Master 1&2, Headphones 3&4
Soundcard: Numark
I have tested the headphones with iPod etc and they work great, but when I plug them into the Mixtrack Pro they do not work.
I have made sure that all settings on the deck/laptop are correctly adjusted so that I would be able to hear sound through the headphones. I have tried adjusting Gain A, Master, and Gain B to try to notice a sound from the headphones, with no luck. I have also tried adjusting the Cue Gain and Cue Mix knobs, and the cross fader, with no luck. I also made sure that nothing on my laptop was set to Mute or low volume.
Everything I use appears to have the most recent update. I am using Windows 7 on a Toshiba laptop, with M-Audio speakers plugged into the back of the Mixtrack Pro through the Master 1&2 outputs. The only things I have plugged into my laptop are the Mixtrack Pro and a Logitech USB for a wireless mouse.
I do not know what else to do. Any help would be much appreciated. Thank you.
My sound setup:
Input: None
Soundcard: Numark
Posted Fri 03 Feb 12 @ 5:26 pm
A couple of things to try...
Uninstall the Logitech device from Device Manager, unplug the mouse, reboot, and start VirtualDJ.
Make also sure that Mixtrack Sound card is set to Quadrophonic. (Right click to the speaker icon on taskbar->Playback Devices->Choose Numark Sound card ->Speakers Config.)
Posted Mon 06 Feb 12 @ 2:03 pm
I just tried those both. No luck :(. Any other ideas? Or is it looking like I should call Numark Tech Support.
Posted Mon 06 Feb 12 @ 8:52 pm
