Does anybody use both arkaos and VDJ together? If so, can anyone help with setup?
Posted Fri 03 Feb 12 @ 6:15 am
I'm trying to find out how to route the VDJ video thru Arkaos Grand VJ also. If i find out any info i will post back here. Good luck!
Posted Tue 12 Feb 13 @ 10:01 am
My good friend Ron does this with his Macbook using the syphon server. Check out his YouTube page/link.
I will also drop him an email to this post.
Posted Tue 12 Feb 13 @ 10:41 pm
If you have a current Mac Book Pro - use Syphon http://syphon.v002.info/ - It works quite well and there is a Syphon Server (used as a video effect) which works perfectly.
Posted Tue 12 Feb 13 @ 10:57 pm
@DjRon, have you used Madmapper with VDJ or do you or have done any projection mapping?? If so what are you using?
Posted Sat 16 Feb 13 @ 10:37 am
