There's nothing wrong with 16 bit audio (I assume that's what you mean). It's CD quality and has been for decades.
Unless you have golden ears and a world class high end hi-fi system, 16 bits is perfectly good enough.
Posted Thu 02 Jul 15 @ 8:18 am
nicholas123 wrote :
sound card Maya 44 is only 16 beats get something better man!
You're answering a question from 2012, now?
Posted Thu 02 Jul 15 @ 2:12 pm
With VirtualDJ 8 you can now use up to 32 bits and any sample rate.
For timecode use (turntables) you need:
1) VirtualDJ 8 Pro (which you already have)
2) 4In - 4Out sound card interface (ASIO and/or Core Audio compatible)
3) Direct Drive Turntables (2 or more at your choice, VirtualDJ can handle 6 turntables or more at your choice at once)
4) Timecode Vinyls, one for each tunrtable you would use with VirtualDJ. This could be VirtualDJ 8 Vinyl, Numark, Serato, Trackor, etc
A suggestion is to have a good computer (something fast like Core i5, i7 4th gen or better to get a fast response).
Check these:
DVS Setup: https://www.youtube.com/watch?v=F1MQjoiWZww
DVS Optimal Settings: https://www.youtube.com/watch?v=-VQ5FKfAIBM
DVS Setup with controllers: https://www.youtube.com/watch?v=ormpQX2p-6U
Check also:
Check these:
Check also:
Posted Fri 03 Jul 15 @ 10:47 am
