hi im pretty new to virtual dj but i think there is a fault somewere unless its me somehow ... what is happening is when u drag the song onto the deck to load it it comes up saying song name ect but doesnt have the grey bar were u can click along it to change wat part of the song u want like a sort of buffer bar and song keeps stopping because of this . its as tho it hasnt buffered to play or something . been stuck trying to fix it for ages anyone think they might know wat it is. thanks all
Posted Mon 30 Jan 12 @ 4:34 pm
what version of VDj are you using?
Posted Mon 30 Jan 12 @ 4:38 pm
using virtual dj7 its the free one but it wont even load song properly ?
Posted Mon 30 Jan 12 @ 4:40 pm
is it all files or just one?
Posted Mon 30 Jan 12 @ 4:43 pm
all the files no matter what song i choose
u know how you have tiny little squares going round the scratch disk and they are grey and they turn blue when u playing ect the squared are only a 1/5 of way round they should be all way round ?
Posted Mon 30 Jan 12 @ 4:45 pm
1 - Make sure your computer meets the requirements found here http://www.virtualdj.com/products/virtualdj/index.html
2- make sure all files have been added to the database, simply right click on the folder where you have your files and click on "Add To Search Database" and scan the tracks for BPMs.
3- make sure you have installed necessary codecs such as K-Lite and/or CCCP and/or DIVX, etc...
Posted Mon 30 Jan 12 @ 4:49 pm
Also check this.
Open VDJ, click on CONFIG, then the PERFORMANCES tab, and make sure where is says "Don't Pre-Load Files Bigger Than: " set this to "infinite"
Posted Mon 30 Jan 12 @ 4:53 pm
yeah i do dunno wat it is i got the bpm its says it 128 and the grey bars just not far enough along cant mix and songs cause it keep ******* up thanks for the advice tho mate just donna wat to do with it ahaha
Posted Mon 30 Jan 12 @ 4:54 pm
what file format are you using, MP3? try using a music CD in your drive see if you have the same result.
Posted Mon 30 Jan 12 @ 4:57 pm
i think ive found out why they wont play u know next to the song u want to choose they have a tiny little yellow question mark next to them wat does this mean ?
Posted Mon 30 Jan 12 @ 4:58 pm
Are you loading files from Netsearch?
all of my songs on my computer come up on virtual dj with a little yellow question mark next to them ?
Posted Mon 30 Jan 12 @ 4:59 pm
yeah from youtube then downloaded it to mp3 from a conveter ?
Posted Mon 30 Jan 12 @ 5:01 pm
yeah i have 2 tracks im trying to mix and the first one has red icon and second one has yellow icon how do i get rid off them so i can play ?
Posted Mon 30 Jan 12 @ 5:02 pm
it means that / those files have not been scanned by VDJ, it know the file is there but if not familiar with it.
The way you are downloading music is not very reliable, and the files are very low quality. You should consider a more reliable source.
Posted Mon 30 Jan 12 @ 5:06 pm
You should be able to play them, the red just letting you know you already played that track
Posted Mon 30 Jan 12 @ 5:07 pm
yea adding it to db sorted it thanks alot mate
Posted Mon 30 Jan 12 @ 5:10 pm
Anytime, thats what the VDJ community is here for. Hope to see you as a Pro User soon and listen to your mixes :) Cheers!
Posted Mon 30 Jan 12 @ 5:12 pm
