Hello fellow rockers,
just got a hercules rmx super happy, I'm just having a couple issues the controller, well ti doesn't let me control enough... i have 3 requests that some one can help me with....
Id like to have it set up that if i press the cue button to repeat a certain part of the song, i can then press play and have it continue on without having to hold the cue button.
also, i was wondering if there was a script to assign one of the programmable keys two work in two ways. if short press, set cue, if short press again it goes to that cue, if long press it deletes the cue.....
And would there be any change to set one of the buttons i.e.: the scratch button to work as a "shift" button on other controller...
Lastly i was REALLY REALLY hoping some one could help me assign the balance knob to control the built in effects...
I know these are all scripts but I'm really untalented when it comes to this (i already tried and had to reinstall vdj cuz i messed it all up)
Thank you in advance!@
Posted Fri 27 Jan 12 @ 1:29 pm
There are mappers which can allow you to do all kind of crazy stuff, but in order to use and download them, you will need :
- Virtual DJ Pro Full
- to enter your serial number into your profile so you can have access to the Download Plugin section.
Posted Fri 27 Jan 12 @ 1:49 pm
alright so i enabled the pro version for 20 days, now what do i do? can anyone help me map them out?
Posted Fri 27 Jan 12 @ 3:44 pm
