I've been Back on the great VDJ Radio. I thought everything was all good. Well, its not. I have developed a gripe with The Software I live and Swear by. Why the heck was the MIC/LINE option removed from the settings? I've been thinking my mixes were normal because you all know if you use a DJ sound card your monitoring comes from your mixer. I listened to some of my sets and they are terrible. I'm thinking people are not hearing what I'm hearing in my headphones, but they do and it records it. Embarrassing might i ad. I'm thinking I'm cueing in the headphones and my crowd is hearing it.
As you all can see I am a VirtualVinyl user. I currently use a lexicon alpha as my main soundcard. I kinda see how this works. I have the alpha set as the main. The VirtualVinyl is not listed. All i want to do is setup my system to operate correctly when im recording in VDJ as well as radio. could someone point me in the right direction?
Posted Sun 22 Jan 12 @ 3:30 pm
Ok...After doing some research, I've came to a probable solution...So I have another question; Why doest the numark virtualvinyl not show in the advanced config?
Posted Sun 22 Jan 12 @ 4:52 pm
It has to do with the way the box was made. Basically the software has out grown the box. It works fine but you cant set it up in the advanced config as youve found out. I was upset about this too. When I called Numark they said theres nothing they can do. I just went out and bought an NI Audio 8 and never looked back.
Huey
Huey
Posted Sun 22 Jan 12 @ 5:33 pm
Thanks bro. Such a shame that we bought that $500 crap...thanks bro...OAN: the DV2 looks like a good investment. I wonder how it works with 4decks...
Posted Sun 22 Jan 12 @ 6:25 pm
