I am running Virtual dj7 Pro with Numark Mixdeck controller.
The problem that im facing right now is that when i load a song into virtual dj deck1, it will show up on deck2 on the numark mixdeck, and its the same with the other side as well. When i load a song into deck2 , it will come up on deck1 of the mixdeck.
Same story with the loop keys, hot cue keys, fx key, play and pause. If a song is playing on deck1 and i wanna apply an effect to that song, i will have to use the fx key on deck2, also if the a loop playing on deck1, i will have to loop it out from deck2. It's kinda hard to use now and its annoying coz now i have to work the opposite way.
Anyone please? How can i fix this??
Posted Sun 15 Jan 12 @ 5:18 am
Hit the "EJECT" button on one of the CD decks, it should switch em back.
Let us know if that works
Huey
Huey
Posted Sun 15 Jan 12 @ 12:30 pm
Posted Sun 15 Jan 12 @ 3:25 pm
