did you use the [square brackets] or the {squigley ones}, you need to use the [square] ones.
Posted Mon 16 Jan 12 @ 2:57 pm
Testing square bracket ..
[Imgur](http://i.imgur.com/BiqO1)
I'm using firefox 9 & ive been here since 2007.. My embedded links have always failed to fully show or are instantly deleted .. Ive had no problems elsewhere using the green syntax.
http://i.imgur.com/NOuwH.jpg
This is all i can view. http://i.imgur.com/cchqp.jpg
I also have a 10 min time out Is this correct?
Posted Mon 16 Jan 12 @ 3:00 pm
