hey guys ive been able to broadcast audio and do live mixing w/o any problems but problem is tryinj to connect my headset ..
some1 pls tell me what inputs outputs i need to setup my headset (mic + headphones). I am puttn the black (headphone) and pink (mic) wire in the front panel of my pc.
I haev realtek and using windows 7 pc with virtual dj pro program. Please hel;p
Posted Sat 07 Jan 12 @ 11:41 pm
First of all, if you have VDJ Pro, please register your serial number at your home page in "Modify My Profile"
That way you'll get more help i think...
Then you have to try these setups:
Input: none
Outputs: headphones
Soundcard: 2 cards
well anyway, something like that... Try and change some of the settngs you get when you have these in- and outputs.
I have 4-mx console from hercules so I use other settings because it has a built-in soundcard.
Input: none
Outputs: headphones
Soundcard: 2 cards
Posted Sun 08 Jan 12 @ 6:50 am
the 2 cars setting doesnt work.. i cant broacast.. remember there are 2 leadss one pink = mic and black = headphone. I cant . please help me select the best setting
Posted Sat 14 Jan 12 @ 3:20 pm
