What do i need to do to connect 2 cdj-2000's to use as midi controllers for VDJ?
Posted Sun 01 Jan 12 @ 10:37 am
From the WIKI,
Set your sound settings in CONFIG -> Sound Setup to the following:
PC:
Inputs: None
Outputs: External Mixer (Deck 1 Chan 1&2 / Deck 2 Chan 3&4)
Sound card: ASIO -> Pioneer ASIO
Click APPLY.
Hope that helps
Huey
PC:
Inputs: None
Click APPLY.
Hope that helps
Huey
Posted Sun 01 Jan 12 @ 11:03 am
You can find latest windows drivers and connectivity here
http://www.pioneer.eu/uk/products/44/106/CDJ-2000/media.html
Posted Sun 01 Jan 12 @ 3:44 pm
does each CDJ need to plug in independently via usb to the laptop? Do these act as midi, or do you have to use timecode cd's?
Posted Mon 02 Jan 12 @ 12:35 pm
of course each unit needs a USB connection, pretty crap that it need to be connected to the computer and not into the mixer. I've said for ages when are they going to have a hub in these mixers? all these cables are pathetic!
They are midi so no need for timecode CD's
Posted Mon 02 Jan 12 @ 1:11 pm
Sorry for sounding ignorant.. I've been using external controllers for so long and havent used cd players much since i switched from Serato.
Posted Mon 02 Jan 12 @ 1:13 pm
