I bought the ergo and the cd was scratched however i have the serial - where can i get the software to validate? Ideally i want to make my pro version work with the ergo however it won't update - can i just copy across the mapping files if i get the LE version to work? Basically i have a brand new ergo that doesn't work and i really can't be ****ed to map it myself hahah !
any help much appreciated (btw I'm on a mac)
cheers x
[EDITED: Please do not use bad language in your forum posts]
cheers x
Posted Sun 01 Jan 12 @ 7:47 am
If you have pro then you just need to update to the latest version of VDJ and the ERGO works plug n play. You don't need to install the LE version too. Drivers can be found on the pioneer website although i didn't need them on my mac. x
Posted Sun 01 Jan 12 @ 9:04 am
If you have a licenced version of Pro then please add the serial number to your profile and update to the newest version.
Older released versions will not work with the Ergo.
Keith
Keith
Posted Sun 01 Jan 12 @ 9:52 am
Register your serial number for Pro on the page https://virtualdj.com/users/edit.html
Then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
If you have not purchased Pro, then you can upgrade from VirtualDJ LE at a discount by going to https://virtualdj.com/buy/ and entering the LE serial number in the box provided. Please support the software and its future development by purchasing it.
Posted Sun 01 Jan 12 @ 1:06 pm
