When i start VDJ it always opens behind the taskbar, i have to drag it into position to the left... can this be changed so that it always opens all the way to the left of the screen (i have the taskbar on the right of the screen), none of the other programs behave like this.
VDJ Opens Like This.
Would like for it to open like this all this time...
Posted Sat 31 Dec 11 @ 1:25 am
When you clos VDJ make sure it's maximized I think.
Huey
Huey
Posted Sat 31 Dec 11 @ 9:07 am
Position your VDJ screen as Huey said, it is in the right top corner of the VDJ screen click the square like icons between the minus sign and x sign it will toggle your screen to position it in minimized and maximized, yours is minimized right now.
Posted Sun 01 Jan 12 @ 4:25 am
my screen is 1366 x 768, the skin is 1280x768.
When I open VDJ the window opens centered on the screen, this means that i have two gaps of 43 pixes on either side.
All i want VDJ to do is to open all the way to the left without maximizing (maximizing increases cpu usage)...
Posted Sun 01 Jan 12 @ 7:22 pm
Yeah I have the same wish.
I always use VDJ on my second screen, which has a higher resolution. VDJ will allways boot back to the first (laptop) screen, while it would prefer it to boot onto the second. Secondly when I choose a skin that is larger than my laptop screen it will warn and disappear. Only way to get VDJ to boot visibly again is to delete the skin registry key.
Posted Mon 02 Jan 12 @ 9:51 am
isn't there an auto resize option somewhere in config?
Posted Mon 02 Jan 12 @ 10:12 am
I have Windows 7 installed on my pc and it always opens full size, no need to resize or maximize the program, and i also have my taskbar on the right. Coud be I maximized VDJ once (the first time i opened it), but i'm not sure.
Posted Mon 02 Jan 12 @ 4:57 pm
Its not about resizing, I would like for windows (i believe this is a windows issue) or VDJ to remember the position of the window the last time it was closed.
Resizing is not recomended because it increases CPU usage, my screen is wider than the skin, all i want it to do is to open all the way to the left... sounds like a simple task that i cant seem to figure out...
Posted Mon 02 Jan 12 @ 10:41 pm
