Hello. I just bought my Numark mixtrack pro. when i got i simply hooked it up to my pc and opend virtual dj 7 pro. Everything worked great. When i was done i unplugged the mixtrack. Later, when i hooked it up everything worked fine and the lights of the mixer came on. But inside virtual dj it wouldn't work? I checked inside the settings and everything was fine except it wasn't listed under mappers. Only keyboard was there. I can choose numark under soundcard and it works, but the controller itself wont work anymore. My friend who also has the controller has the same problem. I even tried installing Traktor and doing everything it said on the manual. I got stuck at step 8. Where i had to select output channel and all that stuff. I did not have any chanels. I only said "Not connected" from the drop down menu in traktor. so i tried using the mixer as audio output and the sound goes through the mixer but it wont work! Just like in VDJ. I even loaded maps for the numark which i downloaded from the internet. it wouldnt work. I've tried uninstalling "Mixtrack Pro" from the device amanger then plugging it in again. It wont work. I've rebooted sevral times, with no luck. all the lights and soundcard works on the mixer, but not the mixer itself.
Thanks for the help,
-Kashif
-Kashif
Posted Tue 27 Dec 11 @ 4:19 pm
i have the same problem. i believe its a problem with the driver and my computer. im not sure though.
Posted Wed 28 Dec 11 @ 3:18 pm
Its a common conflict issue for midi devices that have no native drivers and use the generic windows drivers instead.
https://virtualdj.com/wiki/midinotdetected.html
Posted Wed 28 Dec 11 @ 6:11 pm
