I'm not sure if I'm typing the correct script in to enable me to eq using my keyboard.
I basically want to fade up and down on the mid and low eq's for each deck using my keyboard.
So for example if I wanted to increase the left decks mid eq is the script below correct and if so why is it not working for me.
leftdeck eq_mid +1%
Thanks, Jimmy.
leftdeck eq_mid +1%
Thanks, Jimmy.
Posted Tue 27 Dec 11 @ 3:29 pm
you were close... it should be
deck left eq_mid +1%
Posted Tue 27 Dec 11 @ 5:19 pm
