Hello... I just bought U-Mix Control 2 by mixvibes and i saw that it isnt supported by virtual dj !
I downloaded some Mappings and Definitions but i cant figure out how to make the controller work...
Thanks in advice and plz aswer me as soon as possible :D Merry Christmas
Posted Mon 26 Dec 11 @ 5:12 pm
I need a new controller for my Virtual DJ. In my city (Ufa, Russia) i can buy Numark Mixtrack or new U-Mix Mixvibes.
May i use Mixvibes with VDJ? Or it works STRONGLY with Cross?
Posted Mon 16 Jan 12 @ 6:23 am
Hello! I find recomendation at MixVibes offsite forum. They recommend try mapper MIXVIBES U-MIX CONTROL PRO FOR VIRTUAL DJ for Control 2.
I think, that mapper will be work (at as or after correct).
http://forum.mixvibes.com/XXXX
External link removed.
Posted Mon 16 Jan 12 @ 7:48 pm
you will need to buy vdj pro and register it on the forum to get the mapper for the u-mix, If you want to use vdj with it you will have to purchase this seperately for $300, If you get the mixtrack pro it will come with a le version of vdj that you can upgrade to the full pro for $150 if you choose.
Posted Mon 16 Jan 12 @ 7:53 pm
The correct Def & Mapper link it's this https://virtualdj.com/addons/12899/MixVibes_U-MIX_CONTROL_PRO_Def___Mapper.html
and the PRO version it's necessary to download it.
Posted Tue 17 Jan 12 @ 3:29 am
