I used the 2-way splitter to split the output from my laptop...it kinda worked, but the only problem is that...it didn't split the sound between the speakers and the headphone...but it played the song on deck A on the left earphone and Deck B song on the right earphone...similar to the speakers...do u know how i coud possibly fix this??
Posted Mon 26 Dec 11 @ 10:37 am
make sure your y-cable is STEREO to MONO (L/R). Then Plug L to Speakers/mixer and R to headphones.
in VDJ CONFIG, select MONO SEPARATED
Posted Mon 26 Dec 11 @ 8:30 pm
Before you do what The Magic.DJ said try this: make sure you have the cue gain nobb all the way to CUE and that the crossfader is all the way to the left or all the way to the right depending on which deck is playing out of the speakers.
Good luck.
Good luck.
Posted Tue 27 Dec 11 @ 8:12 am
