If I'm completely mistaken on my first assumption, please correct me and explain the easier, or proper, way of doing this. But, I just recently purchased a Numark Mix Track Pro. I broadcast via shoutcast a lot, and typically just use a combination of my computer's soundcard and speakers for the Master, and my USB headset for the Secondary. I'm wanting to add the ability to come over microphone and talk via the mic on my USB headset while streaming. I read in another post that this could only be accomplished using ASIO4All. I've installed it, and successfully achieved the ability for my computers soundcard to output to the speakers (whether they're set to Master OR Secondary).. and the microphone works as well. However, there is absolutely no sound coming from my USB headset, whether I set it to Master or Secondary. Does anyone have any suggestions on what might be happening or what the problem could be? I'm also not opposed to the idea of getting a headset and microphone separately and hooking them in directly to the Numark, but I've also read that will not send out the audio from the microphone if I'm broadcasting in another forum here on the VDJ website. Looking for any and all answers, tips, or suggestions. Thanks!
Posted Sat 17 Dec 11 @ 4:14 pm
Disregard. I was looking for a delete post option but was unable to find one. My brother let me borrow a microphone to plug directly into my Numark and everything works perfectly without the need to set up ASIO. Will be purchasing one for myself ASAP. Great software, guys.. keep up the good work!
Posted Sat 17 Dec 11 @ 6:49 pm
