So I have two American Audio Radius 3000s and i have them connected using them as midi controllers and they are working great except I can't use the key lock which was a feature I really liked. With the pitch changer it gets me to the tempo I need but anything over a 5bpms sounds ridiculous and the keylock helped that a lot. Any ideas on how I can fix this?
Posted Thu 15 Dec 11 @ 7:13 pm
with mapping you have two options
master_tempo : activate/deactivate the master tempo (to make the pitch slider change the speed of the song, but keep the original key of the song).
key_lock : activate/deactivate the key lock (to make the pitch slider change the speed of the song, but keep the key of the song like it is now).
I prefer "master_tempo" or you just can press the lock near the pitch slider on the skin to activate key_lock.
Posted Thu 15 Dec 11 @ 7:43 pm
If you can't activate key lock, please see: https://virtualdj.com/wiki/PureScratch.html
Posted Fri 16 Dec 11 @ 6:57 am
Ah, thanks. That's what I was looking for.
Posted Fri 16 Dec 11 @ 2:26 pm
hey i have 2 radius 3000's and i have them hooked up to my labtop and im using vdj 7.0.5 and when i go to mapp them vdj is not reading them its only saying simple midi wrapper. i even tried selecting radius 3000 in the selected devices and it still wont work so my question is
HOW CAN I GET VIRTUAL DJ TO READ MY AMERICAN AUDIO RADIUS 3000?
AND CAN YOU SHOW ME THE STEPS?
Posted Tue 18 Sep 12 @ 1:02 pm
