Hi my fellow DJs
Long time user but 1st time poster.
Hopefully I have a simple problem that requires your help. Running my Numark Mix Track Pro with my MAC and rather old Amp and speakers.
Trying to output the Audio from Mix Track to another PC Laptop which will enable me to put on live Webcam/Audio shows. As soon as I put in the audio cables i'm getting a loud humming noise (sounds like a bad earth)
Been trying to play around with audio setting on virtual dj to no success.
Any advise would be gratefully appreciated.
Posted Thu 15 Dec 11 @ 4:23 pm
This is most likely a ground loop issue and you will need to purchase ground loop isolator(s) to resolve it.
Please see: https://virtualdj.com/wiki/Ground%20Loop.html
Posted Fri 16 Dec 11 @ 6:55 am
