Topic: Numark Mixrack and VirtualDJ Broadcaster?
Hi, does anybody know if the numark mixtrack is compatible with the Broadcaster version of the VirtualDJ?
Posted Thu 15 Dec 11 @ 3:06 am
Mixtrack will work with the supplied LE or Pro versions only. Broadcaster does not support multi channel sound cards.
Keith
Broadcaster does not support using any MIDI controllers (It's for mouse+keyboard only), except for 10 minutes at a time as a trial of the full Pro.
As above, you will either need to use the VirtualDJ LE if your MixTrack came with it or upgrade/purchase the full VirtualDJ Pro: https://virtualdj.com/buy/ - If you have LE, you can upgrade at a discount.
