I'm trying to livestream some mixing but I've got an audio problem. The only way for me to broadcast audio is to use the stereo mix. I'm very aware of how to do this but the stereo mix doesn't get any audio since I'm using the sound interface in the Mixtrack Pro.
I have the Mixtrack Pro hooked up via usb, and then my speakers hooked up directly to the Mixtrack. I know that I could just plug my speakers back into my onboard sound card and broadcast audio with stereo mix but then I get issues with volume gain when switching the cue'd deck.
I'd rather just figure out a way to stream audio with the current setup. So I guess something that takes the audio going through that usb connection and puts it through my soundcard. I've messed around with Virtual Cable a bit but haven't found a solution with that either.
Any suggestions?
Any suggestions?
Posted Tue 13 Dec 11 @ 7:27 pm
If the volume of the PFL/CUE Deck is not equal or it is something like main out and headphone audio is going up or down when you press the CUE/PLF that means that your sound setting in the config is wrong, you have to route your mains, headphone, booth outs correctly by setting them in the "config" menu then "sound setup" then choose the ouput "advance config" and click the + sign to add the decks, mains, headphone and your soundcard outputs, something like this: ( Deck 1 = Outs 1&2, Deck 2 = Outs 1&2, Main Outs = 3&4, Headphone Outs = 5&6 ) this is just and example try to tweak and experiment them until you get the exact setting of your soundcard. Goodluck.
Posted Wed 14 Dec 11 @ 4:50 am
