So I downloaded the free version while messing with the settings I accidentally changed the size or something and now it is zoomed in to the point of not being able to click the configure button on the top right. Ive uninstalled it and reinstalled it like 10 times and tried every thing I would really appreciate it if someone helped.
Posted Thu 08 Dec 11 @ 8:28 pm
If you see this on the splash screen hit cancel, to go back to the default skin for your screen size.
Posted Thu 08 Dec 11 @ 11:21 pm
thats not exactly what is happening, when it loads instead of being in the middle of the screen it is bigger and closer to the bottom right then the program opens up so big that I cant change it. I can see about 65% of the complete window (It cuts off in the middle of the second deck)
Posted Fri 09 Dec 11 @ 1:08 am
Press Ctrl + Alt + Delete open up the task manager select Virtual DJ. Now go to the top of the task manager select windows and then maximize. This should make VDJ fit to screen so that you can go into the config to change the skin to one that marches your screen rez.
Posted Fri 09 Dec 11 @ 4:06 am
Before launching Virtualdj, rightclick on your desktop, choose Personalize and make sure the font size of the desktop is set to small (not medium or large).
Posted Fri 09 Dec 11 @ 1:40 pm
It worked thank you so much!
Posted Fri 09 Dec 11 @ 5:00 pm
