i have just got a new pc i am usesing vdjpro and the videos are stuttering but the sound is ok if i take the hardware acceleration off in video it stops it but dose not go to my tvs i have been told its something to do with the graphics card its a
acer desktop touch screen windows 7 64bit 1.5tb hard drive 4gb ram
please help if you can cheers tony
Posted Tue 06 Dec 11 @ 6:04 pm
What video card is installed, and the specs?
Posted Tue 06 Dec 11 @ 6:08 pm
• Intel® Core™ i5-2400S processor i dont have the pc here at the min to find out the graphgics card in it
Posted Tue 06 Dec 11 @ 6:15 pm
If it's an i5 2400 series with a touch screen, it likely has the NVIDIA GT520 as well as an Intel graphics card. Try assigning VirtualDJ to use the high performance card by doing the following:
1 - Click Start and then Control Panel. Select Classic View from the left side of the window.
2 - Double-click NVIDIA Control Panel.
3 - Click View and next Add "Run with graphics processor" Option to Context Menu. Close the NVIDIA Control Panel.
4 - Right-click the VirtualDJ icon on your desktop and select Run with graphics processor. Then, click High-performance NVIDIA processor.
This is the most common way to do this, but control panels do vary so you may need poke around in your performance graphics settings to assign it to the program.
Posted Tue 06 Dec 11 @ 6:45 pm
