I'm noticing that when certain effects are engaged, the volume will slightly lower on the track until the effect is disengaged.....Sound familiar to
anyone????.....no other issues...playbk is smooth, waveform running smooth, offline lappy....Thanks forum!!
Posted Sat 26 Nov 11 @ 3:49 pm
Which effect(s) are u using when you encounter this?
Posted Sat 26 Nov 11 @ 6:43 pm
echo, echo doppler, bit crusher are the ones that I have noticed so far......It's sounding like a hardware spec issue to me, but I have NEVER had any
performance issues with my laptop. 2Gb dual core, 4GB RAM and everything stripped down for audio reproduction. Latency Monitor- perfect,
etc....I'm clueless to the problem......
Posted Sun 27 Nov 11 @ 12:44 am
