Hello,
I have a problem with my DDJ ergo and the loop control.
When I activate smart loop, sometime ( most of the time when it's 2 time ) the sound go off at the end of the loop and work again when the loop go to the begin.
I never saw that with my hercules steel control.
Can someone help me ?
I already try this :
reinstall VDJ pro from "sratch"
Posted Fri 25 Nov 11 @ 6:22 pm
I have had the same issue, doesn't happen every time, but It does cut out for only one loop, then the sound comes back. Only difference is I am using the Mixtrack Pro
Posted Sat 26 Nov 11 @ 4:46 am
I also have this problem - I'm using the Denon DN SC2000
Posted Fri 09 Dec 11 @ 4:43 am
You have this problem since last version ?
Posted Fri 09 Dec 11 @ 5:24 am
There you can see my problem on youtube :
http://www.youtube.com/watch?v=kqvLF8OK1SU
please can someone on VDJ fix this bug ?
Posted Sat 17 Dec 11 @ 4:17 am
