Topic: Headphone and Speaker problem with PFL/Cue
I'm having a problem with my set-up, When I cue a song the song plays through both the headphones and speakers, when i only want it to work through the headphones, how can i set it up to work?
Posted Tue 22 Nov 11 @ 8:20 pm
How about providing some information?
For example - what is your setup?
I am using an Numark Mixtrack(not pro). I have an internal soundcard. An old one, I think Echo mia, some old card I found. I have it working but the only problem is when the cued song is playing it plays both through my headphones and speakers when i want it only through my headphones so i can mix properly.
http://www.echoaudio.com/Products/Discontinued/Mia/index.php
This is the link to my soundcard, if it helps.
You would have to Get Two Soundcards for This work.if not so you gotta Buy your self a Numark Djio or Vise Versa
Damn, that sucks, could i use my onboard video card? If i configured it?
Hey guys, I am new to the forums but had a cue/headphone question:
My set up is a Denon MC3000, VDJ LE that came with it and Rokit 8 monitors with Rokit 10 sub.
This weekend I noticed my cue and headphones were not working properly. For instance, while I tried to play the left A deck and cue up the right B deck, I could not get my head phones to play the music without having both cue lights on. However, once I turned on my B cue, it would start playing that song through my monitors even with the fader all right way to the left track. Does anyone have any trouble shooting to this problem? I assumed it was just technical software glitch and tried restarting but it kept doing it.
Thanks
You have to be a registered user, or have the LE version that your controller came with, to have this function. If you bought this controller used, then you may not have the software that it came with.
AMAHM you're answering a post from 2011 :-)
That's funny because I just locked an old thread. My bad.
