Is it me, or has anyone noticed degrading sound quality when using some of the 99 decks?
I noticed when I play more than three decks at a time and enable say.. texzk reverb and filter on all three, i get nasty crackling and pops. The more decks I play with effects turned on for each deck, the worse it gets.
I am on a quad-core 3.2ghz gaming laptop stripped down for DJ'ing and a Echo audiofire sound card. Tried varios ASIO rates, nothing really helps.
Is this a VDJ sound engine limitation?
Also, I used the other decsk to launch samples sync'ed with the music (i run the Gates effect on them to simulate a sidechain, works great when the sound is clean!)
Posted Sun 20 Nov 11 @ 4:53 pm
Tex's reverb is a is a cpu hungus, Look for a free vst plugin on the internet, there are many available, that will use less cpu
Posted Sun 20 Nov 11 @ 6:42 pm
You may be right. Unfortunately, I haven't found a good free reverb that keeps reverbing even after I've stopped the track. All the vst plugins stop once the track stops.
Posted Sun 20 Nov 11 @ 7:17 pm
it is impossible to do that, you need the track running to effect it, but tex's is the only one I have found with such a powerful wet/dry slider, but that is why it uses so much cpu I think..
Posted Sun 20 Nov 11 @ 7:44 pm
