I have set up the timecoded vinyls with a MK2 Hercules DJC. Now, The signal is fairly clean and vinyls are responsive, speed margin jumps about +/- 0.1 which is great. But the signal strength sometimes drops from 100% just for a fraction of a second and goes back up. Now, my hearing is not perfect but i think I can notice that while the music is playing. I tried everything, used noise LP filter to minimize noise and clear up the signal but cant see the difference.
1. My question is, as I'm using Tractor timecoded vinyls that have been used, could I accomplish better signal by simply cleaning them? If yes, how?
2. Could this be due to the heads although they are practically new?
3. Could it be due to anti-skate setting? I didn't tamper it much and I also didn't notice any difference twiddling with it.
4. Could it be the MK2 inputs have something with it?
Thank you!
P.S. When I get home I'll post screenshots of Debug window.
Thank you!
Posted Fri 11 Nov 11 @ 1:37 am
Don't want to be rude or so but your version of VDJ (same as mine) does not support timecoded setup. Are you using a cracked version?
Posted Fri 11 Nov 11 @ 2:29 am
Nope, a free trial, you get like 10 minutes of timecode goodness... If I get it to work ill sure buy the full product. This is for testing.
Posted Fri 11 Nov 11 @ 4:03 am
Posted Tue 15 Nov 11 @ 8:27 pm
