Hi,
I would like to have the jogwheels of my hercules rmx work like this:
When the track is stopped have it in scratch mode, when it is playing use it for pitch bending.
Can this be achieved and if yes, how?
Any help is very much appreciated.
--Thomas
--Thomas
Posted Thu 10 Nov 11 @ 10:24 am
Yes, go to CONFIG -> Options and set Jog Mode to CD.
You can also adjust the sensitivity there for each mode.
NOTE: If it has a SCRATCH button, then this will toggle between vinyl and CD modes.
Posted Thu 10 Nov 11 @ 10:27 am
You're blazingly fast... :-)
I'll check this out when I'm back home...
Posted Thu 10 Nov 11 @ 10:29 am
OK, After Checkin this, this is not what I wanted.
I meaned, I want the Jogs to Scratch(Vinyl-Mode ) while the track is not running and automatically switch to bending (CD-Mode) when it starts playing.
Posted Thu 10 Nov 11 @ 1:33 pm
That's exactly what CD mode does. It will scratch for cueing if the song is paused and will only pitch bend when its playing.
If the scratch response isn't right, you can adjust it using the sliders in CONFIG -> Options
Posted Thu 10 Nov 11 @ 2:02 pm
Ahh...now i've got it! Works perfectly.
Great thanks!
Great thanks!
Posted Thu 10 Nov 11 @ 2:53 pm
