Alright guys, I'm trying to figure out the best way to control loops in VDJ
Preferably, I would like to use my MIDI controller and use on of the knobs to control loop size, either though VDJ directly, or through a VST
Any suggestions on how to do that?
The standard VDJ loop works okay, but some times i need to loop 1/2 beats and such, and I don't like programing one key to do a half loop, another to do 1/4, another for 1/8th etc....
Ideas and suggestions BELOW!
l
l
V
l
l
V
Posted Sat 29 Oct 11 @ 5:54 pm
Personally I have 1 knob to control the size of loops as well as the in button set to cut the loop size in half when shifted and the out button set to double the length when shift is pressed this allows fast loop rolls with the knob and easier control with the buttons when you want to slowly increase or decease the size of the loops. I also mapped my pitchbend buttons to move the loop forward or backward for looping different parts of words or to make strong buildups or transitions. There are many different ways to control loops in VDJ you just need to find whats right for you. Hope this helps!
Cheers,
DJ Cool Colors
Cheers,
DJ Cool Colors
Posted Sat 29 Oct 11 @ 11:30 pm
any way you could lend me the script for that?
Posted Sun 30 Oct 11 @ 2:17 pm
