hi all im prob not in the right topic page but need help plz.. im using v-dj on my home pc were iv hot cued most of my tracks but now iv been asked to play out on some of my own gigs i cant drag my pc around with me so is there anyway i can copy the hotcues that iv made for my mp3s from pc to laptop without manully doing it all again?
Posted Thu 27 Oct 11 @ 6:47 am
What version of VDJ are you using, and what operating system are you running?
Posted Thu 27 Oct 11 @ 11:42 am
hi im using vdj 7 pro in windows vista, laptop also visa
Posted Thu 27 Oct 11 @ 12:09 pm
Hook up an external drive and transfer your through VDJ over to the external drive. Now you will have all that info and can use it with any laptop that's running VDJ.
Hope that helps
Huey
Hope that helps
Huey
Posted Thu 27 Oct 11 @ 12:25 pm
I believe you just need to copy over your drive's database file. Mine is on my "M:" drive so I copy the file "VirtualDJ Local Database v6.xml" over to my other machine's "M:" drive.
I clone both drives to ensure there are no confilcts. And I don't know why the database is not named v7. Perhaps next release.
Posted Thu 27 Oct 11 @ 12:57 pm
ok cool ill try that thx for ya help
Posted Thu 27 Oct 11 @ 12:58 pm
@beatbreaker1 tryed it and it worked thx alot cheers
Posted Thu 27 Oct 11 @ 2:03 pm
No thanks needed, just support the software and buy the PRO version ;-)
Good Day
Huey
Good Day
Huey
Posted Thu 27 Oct 11 @ 2:06 pm
